Please check my proposed water setup.
shadow2761
Would anyone be able to look at my build and the EK parts chosen and to verify if you think this would all be compatible and feasible for my build. And if you can suggest anything else to purchase for improvement or reliability, please do so.
My current system I already own is:
EVGA SuperNova P2 1000W
Asus Z390 STRIX-E
i9-9900K
EVGA RTX 3090 FTW3 Ultra
2x8GB Trident Z 3600 C14
I am looking to cool the CPU and the GPU (non-vertical).
The case I will use is a LianLi O11 XL Dynamic with 6x Corsair LL120 Fans and Corsair Commander Pro, and Lighting Node Pro. I will be using Barrow or Bykski chrome plated copper metal rigid tubing pre bent.
The EK parts for the water loop I have chosen are:
  • EK Quantum Magnitude 11XX Full Nickel
  • EK Quantum Vector FTW3 RTX 3080/3090 D-RGB - Nickel + Plexi
  • EK Quantum Vector FTW3 RTX 3080/3090 Active Backplate D-RGB - Plexi
  • EK Classic DP Side PCO11D G1 D-RGB + DDC 4.2 PWM
  • EK Quantum Torque HDC14 Black Nickel (x16)
  • EK -AF Extender 8mm M-F G1/4 - Black Nickel (x2)
  • EK Quantum Torque Rotary 90° - Black Nickel (x4)
  • EK Coolstream XE360 (Triple)
  • EK Coolstream Classic PE360
  • EK CryoFuel Clear 1000ml
  • EK ATX Bridging Plug
  • EK Cable Pump Testing adapter
In this video below will be the sort of watercooling setup I aiming to achieve in terms of looks:
Please let me know if you think the EK parts chosen above and my PC system specs listed above are compatible to achieve a similar watercooling build like in the linked youtube video. Thank You.
shadow2761
Well EK just told me the FTW3 Water block will not fit in the O11 XL Dynamic case in horizontal position. The water block is too big and I would not be able to put the side panel on :(
