CharlesRenault
- May 20, 2014
Please help me understand the proper configuration. I don't just want to get it right, I want to understand why one is the proper model and why the others aren't.
I can't help but think a lot of people may write it really won't make a difference but I'm sure one is standard, there's got to be a logic to this and that's what I'm aiming for.
In case my quick write-up isn't clear, the switches are distanced apart by walls that can be drilled through but that will take several days of crawlspace work and sheet metal drilling.
Thank you, all.
Setup A [Router: only one (1) LAN port used total]
Router {port 1} --> Managed Switch # 1 --> Respective Devices/clients
Managed Switch # 1 --> POE Switch --> Respective Devices/clients
Managed Switch # 1 --> Dumb Switch --> Respective Devices/clients
Setup B [Router: two (2) LAN ports used, each to a switch]
Router {port 2}--> POE Switch --> Respective Devices/clients
Setup C [Router: three (3) LAN ports used, each to a switch]
Router {port 2} --> POE Switch --> Respective Devices/clients
Router {port 3} --> Dumb Switch --> Respective Devices/clients
------ ------ not as important as above --- ---
Setup D [Router: two (2) LAN ports used, each to a switch]
Managed Switch # 2 --> Respective Devices/clients
-- {LAG / LACP} --
Managed POE Switch --> Respective Devices/clients
-- {LAG / LACP} --
Thank you, all.
-- {LAG / LACP} --
-- {LAG / LACP} --
