Playstation Neo to Feature a Polaris GPU and 4.19 TFLOPS of Performance
SamiiRoss
Finally they will be able to play at fullHD
Playstation NEO Technical Specifications
WCCFTech PS4 PS "NEO"
CPU Codename Jaguar
Primary CPU Configuration 4 + 4
Auxiliary Processor Yes
Clock Rate 2.1 Ghz
GPU Codename Polaris derivative
Control Units 36
Stream Processors 2304 (TBD)
GPU Clock 911 Mhz
Memory Clock (Effective) 1703Mhz (6812 Mhz)
Memory Bus 256 256
Rated Floating Point 4.19 TFLOPs (TBD)
Bandwidth 218 GB/s
Unified Memory 8GB GDDR5 (+250 MB DDR3)
Process 14nm FinFET
N/A
Read more: Upcoming Playstation Codenamed "NEO" - Features A Powerful Polaris GPU and 4.19 TFLOPS of Performance
im going take this with a salt mine polaris likely no a shrunk 28nm apu yes also the chip you have posted is the 28nm apu....
