rsbennett00
- Aug 16, 2012
Anyone know how DS4 compares in feel to the razer sabertooth? The sabertooth has the best dpad I've had in a long time.
No point. Just use the 360 controller.
Anyone know when the steam controllers come out?
I for one will never purchase a console; however I wonder how much the ps4 controller costs when you can purchase many types of gamepad controllers to use on a pc for a small amount of money.
I remember someone arguing that the reason why the 360 controller for Windows and other video game controllers was better is that controllers are built to last and to withstand great amounts of abuse, especially from little children. PC controllers on the other hand, not so much so their quality varies greatly.The PS4 controller should be in the neighborhood of $60. Why get it instead of a cheaper PC gamepad? IMO, you get what you pay for. Most cheap PC gamepads are complete garbage with cheap parts, questionable compatibility, and lousy d-pads/analogs. Even the usually dependable Logitech's controllers tend to be junky, and they aren't even all that cheap.
The good PC pads are the 360 Controller ($34-40 depending on if you want wireless), the similarly priced PS3 controller (which requires some tinkering and 3rd party software), and the Razer Sabertooth...which is $70. The other alternative is buying a PS2 controller and a USB adapter...which honestly isn't too bad, although support for modern games requires additional 3rd party software.
Sony claimed that "real" drivers are on the way for the PS4 pad eventually, and I'd say it's arguably the best controller on the market in terms of build quality.
Hows the Analog sticks for precision aiming compared to the xbox 360 pad? Is it noticeably better or about the same?
I've been playing with this on a USB cable yesterday, works flawlessly, except for a small oddity in one game. (The Y axis was completely backwards on the left stick, in Racing Room Experience, but since you don't use up and down in game its was perfectly playable.) Played some Jamestown with friends on other controllers, flawless. Burnout paradise, perfect. Pretty much what happens when you plug in a PS2 controller into a PC with one of those USB adapters.
Tried out some old school emulators, SNES, PC Engine, Sega Genesis, PSX, all as expected, the controller feels great with all those games.
Games I know work universally(DirectInput) is all I've tried.
Currently you need a Xinput emulator to work on X360 only controller games. I'm going to try those soon.
So out of the box, it won't work with those games. (Darks Souls, Pinball Arcade, Final Fantasy 7 all registered no button presses at all, even when I disconnected my 360 controller from the PC completely.) In Hotline Miami, on the other hand, it is picked up and mapped exactly how it is on the 360 controller, ready for action.
I tried pairing with bluetooth all day but could not get it to stick. It would connect and then disconnect pretty much immediately.
Oh well, had a long enough cable, no fatigue, good sessions..... This was last night.
Had an idea this morning.....
To pair your Playstation 4 Controller to your PC:
(Obvious: Bluetooth dongle, or built-in connectivity on your PC is required)
1. Hold the SHARE button and then press and hold the PS button until the lightbar starts flashing.
2. Open your Bluetooth properties and select "Add Device" so your PC will scan for it. It will come up as "Wireless Controller". Select to pair with that device.
Now normally mice and controllers pair by bluetooth automatically with no need for authentication, but it seems that the PS4 controller is different. If you try to pair without passcode, the controller will never bind and will continue flashing for a bit and turnoff. It loses connection when this happens.
What you want to do is pair it using passcode. The passcode that apparently works is '0000'.
After I paired it with that code, the lightbar immediately lights up steady and keeps a connection.
Works exactly like when wired.
Only issue now is xinput only games, those look for 360 controllers and nothing else, which is nothing new really...
I will try the xinput emulator soon.
Theres a little bit of work in pasting dll's into game directories, don't feel like it right now
UPDATE:
X360ce is here:
https://code.google.com/p/x360ce/downloads/detail?name=x360ce.App-2.1.2.191.zip&can=2&q=
x360ce libraries:
https://code.google.com/p/x360ce/downloads/detail?name=x360ce_lib32_r789_VS2010.zip&can=2&q=
shameless rip from neogaf
So you hold the PS button for like 10 seconds to turn it off, and the controller remembers the pairing. Hold the PS button to turn it on, it will connect back with the PC.
I also just tried x360ce with Dark Souls, it works flawlessly if you follow the above instructions. Very nice indeed.
UPDATE2:
Another tool. Xinput wrapper
This one you don't need to mess with files in game directories.
Instructions and download are at the link below.
http://forums.pcsx2.net/Thread-DS4-To-XInput-Wrapper
I went out and grabbed a DS4 controller tonight and have it working pretty well so far. The only problem I'm having is it seems to press the button twice when in Steam Big Picture mode.
I installed a plugin that lets the touchpad work like a mouse, and so far, I'm very impressed. Here's a link to the Reddit thread with a link to the file:
http://www.reddit.com/r/ffxiv/comments/1qfk7c/ps4pc_use_your_ps4_touchpad_as_a_mouse/
brother im using a laptop not a pc if you mean
