WhoBeDaPlaya
- Dec 16, 2002
m1919 : The 750Ti seems a little out of place. PhysX? Or to drive extra monitors?
My bad, missed that somehow.They said in the post that it is being used to drive their other monitors so the 1080s will properly drop to idle clocks.
You would just need two of the same spec. So two x5670s for example are what I run in one of my servers that aren't a matched pair. It just has to be the same model.do i need to buy a matched pair of cpus or can i just get 2 the same spec and fit those? ones i was bidding on went over budget at £80
This is a showoff thread, not a how to build a dually rig thread.i got 2 x5670s for £79 and free postage,but i dont have ecc memory does this matter ? as says not supported with the cpus i have and supported with x5670s.
Damn son, time to dust that thing off...
Have you tried running Windows 10 on that X5670 system?
