I've used PHP before, but nothing past the basics, however I do understand quite a few of the commands and concepts due to their relation to C+/C++. What I wish to do is create a simple program that I will run on my web server, which will query another server, take data and mirror it.
E.g.
www.mywebserver.com/phpscript will mimic the data on www.site.com/1
However, to access www.site.com/1, you need to login via an html-based login. So when you try to connect to www.site.com/1, you get redirected to www.site.com/2 where it asks you to input user and password data in an html form.
I have an account for www.site.com/1, but I have no idea how I could get a PHP program to "send" the user/pass over when it connects to www.site.com/1, bearing in mind it uses html-based form login, not a HTTP popup.
Also, how would I get it to take data from a table? Ive worked with xml forms a bit, taking specific values, but Ive never tried it with html.
Hope you can help, as I would really find a use for this program when I create it.
Thanks a load!
Zxcs
E.g.
Thanks a load!
Zxcs
