Php Error
Shockey
Parse error: syntax error, unexpected T_SL in /var/www/shockey/admin/preupload.php on line 15
Could someone possible look this over for me. This is my first time dealing with HEREDOC syntax. I think i have an understanding of it, but I remove the space at the end of the line and it appears to break the rest of the script. (Notepad++ turns the rest gray)
I tried running it just for heck of it, Same line error shows up(Line 15)
Code:
<?php
 include 'config.inc.php';
 // initialization
 $photo_upload_fields = '';
 $counter = 1;
 // If we want more fields, then use, preupload.php?number_of_fields=20
 $number_of_fields = (isset($_GET['number_of_fields'])) ?
   (int)($_GET['number_of_fields']) : 5;
 // Firstly Lets build the Category List
 $result = mysql_query('SELECT category_id,category_name FROM gallery_category');
 while($row = mysql_fetch_array($result)) {
[COLOR="Lime"]   $photo_category_list .= <<<__HTML_END  [/COLOR]
<option value="$row[0]">$row[1]</option>\n
__HTML_END;
 mysql_free_result( $result );
 // Lets build the Image Uploading fields
 while($counter <= $number_of_fields) {
   $photo_upload_fields .= <<<__HTML_END
<tr><td>
 Photo {$counter}:
 <input name="photo_filename[]"
type="file" />
</td></tr>
<tr><td>
 Caption:
 <textarea name="photo_caption[]" cols="30"
   rows="1"></textarea>
</td></tr>
__HTML_END;
   $counter++;
 // Final Output
 echo <<<__HTML_END
<html>
<head>
<title>Lets upload Photos</title>
</head>
<body>
<form enctype="multipart/form-data"
 action="upload.php" method="post"
 name="upload_form">
 <table width="90%" border="0"
   align="center" style="width: 90%;">
   <tr><td>
     Select Category
     <select name="category">
     </select>
   </td></tr>
   <!—Insert the image fields here -->
   <tr><td>
     <input type="submit" name="submit"
       value="Add Photos" />
   </td></tr>
 </table>
</form>
</body>
</html>
__HTML_END;
Thank for any help!!!
Tweakin
From what you have pasted there, you might be getting the error due to the white space after __HTML_END;
With heredoc's in PHP, you can not have any white space (including tabs) before or after the closing heredoc tag.
Edit: Just did a quick search on your error, and came up with a post asking the same question and, funny enough, using your exact same script above! :)
http://www.phpbuilder.com/board/showthread.php?t=10333424
They resolved the issue there.
Shockey
Yeah. I found that also i got the same error before after fixing it. Maybe i screwed up. not sure. Anyway now i receive this.
Parse error: syntax error, unexpected $end in /var/www/shockey/admin/preupload.php on line 67
?> (end of script) progress :p
Appears i missing curly bracket
