Phinix. Amazing job.
Do you realize that of your 3 fans next to each other, only 2 of them are blowing the same direction? Or is that on purpose?
Great job phinix!!!
This is some amazing work, i cant wait to see this thing finished
I have three questions for you,
1. What program did you use to draw up the design? I see there are fans and stuff in there, were those prebuilt or somethign you designed?
2. Did you get the aluminum peices laser cut? (the ones with the nano shapes) If not what how were they cut?
3. How thick is the actual powder coat? So say you use a 3mm thick aluminum sheet, what is the thickness after powder coating? 4mm? I guess youll need a micrometer for that.
Keep up the amazing work
Thanks
Also, is that the Hazro HZ27W*? (2560x1440). If so is it the 8bit or 10bit? What's it like?
What? You mean the mirror on the desk?
Glossy as hell aint it? lol Supposed to be excellent apart from that though
Wahey!! Almsot there mate! What a mess though
Just briliant. Keep it that way.
im super stoked for the weekend final update!
