If any of you are hairy like me, you'll be at home with this system It's the absolute top of the line philips norelco razor (1290X [$249 retail!]), and comes with the jetclean charging and cleaning base which isn't available with the 1290x in retail anymore (you only get a flimsy charger).
I know what you must be thinking, a used razor? Well I cleaned the shaving head with hot water, isopropyl rubbing alcohol, and the Philips Jet Clean solution, so you have nothing to worry about.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300911983083
