This is the first I've heard of these issues, and they might drive me even more insane than some of the other concerns people have posted. Are others having their windows resize like this when they turn their monitor off and back on? And do you really have to freaking hold onto the power button for 3 seconds to turn off the monitor?? I frequently get up and shut off my monitor when I'm about to leave. After a week of use I'm going to start hating this thing if that's the case.
Yes all of what he said about turning off and on is true, if you turn off then turn it on it will resize things, at least in my monitor it comes back to the 4k resolution, but ofc by that time it has already screwed up previous window placement, icon placement and sizes, if you have ever had SLI and had to disable it, it's pretty much like that.
Even if this wasn't true, the on off button is in a somewhat hard to reach place, so really it's not something you will want to do.
EDITED:
BTW to clarify I believe this is a problem with the way the display port works, so if I'm not mistaken you will get this on all monitors that use DPI, at least assuming their on/off switch actually cuts all the power, like the philips.
If this however is very important to you, you might want to look at monitors/tv's with HDMI 2.0, maybe the problem doesn't exist with HDMI 2.0 (no idea if it does or doesn't).
I don't ever turn my monitor off.
It goes to sleep, so why would you want to power it off?
I assume the idea is to not waste power, although truth be told, the power usage when in standby is pretty insignificant, according to the manual we are talking about less than 0.31w, which means after around 8.5 days you have wasted 1 hour worth of watching the monitor (assuming you didn't need another device to watch something on it).
