Philips BDM3275UP - 32" 4K IPS monitor
Discussion in 'Displays' started by Phuncz, Jul 3, 2015.
  1. Phuncz
    Phuncz 2[H]4U
    2,630
    Apr 12, 2009
    So this one got announced recently. It might not be a revelation but it seems like a good display with 10-bit panel and 12-bit internal processing, the most important video ports, "FlickerFree" technology and a fully adjustable base.
    Philips BDM3275UP
    4K Ultra HD LCD display with MultiView
    32" / 81.3 cm 4K Ultra HD (3840 x 2160)
    Support page: http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=BDM3275UP/00&hlt=Link_Overview&scy=NL&slg=AEN
    Brochure (PDF): http://download.p4c.philips.com/files/b/bdm3275up_00/bdm3275up_00_pss_.pdf
    Specifications:
    Picture/Display
    • LCD panel type: IPS-AHVA LCD
    • Backlight type: W-LED system
    • Panel Size: 32 inch / 81.3 cm
    • Effective viewing area: 708.48 (H) x 398.52 (V)
    • Aspect ratio: 16:9
    • Optimum resolution: 3840 x 2160 @ 60Hz
    • Response time (typical): 12 (GtG) ms
    • SmartResponse (typical): 4 ms (GtG)
    • Brightness: 350 cd/m²
    • Contrast ratio (typical): 1,000:1
    • SmartContrast: 50,000,000:1
    • Viewing angle: 178º (H) / 178º (V), @ C/R > 10
    • Picture enhancement: SmartImage
    • Display colors: Color support 1.07 billion colors (10-bit)
    • Scanning Frequency: 30 - 83 kHz (H) / 56 - 76 Hz (V)
    • MHL: 1080P @ 60Hz
    • sRGB
    • Brightness uniformity: 93 ~ 105%
    Connectivity
    • USB: USB 3.0 x 4 with B.C.1.2
    • Signal Input: VGA (Analog ), DVI-Dual Link (digital, HDCP), DisplayPort, HDMI (2.0) - MHL x 1
    • Sync Input: Separate Sync, Sync on Green
    • Audio (In/Out): PC audio-in, Headphone out
    Convenience
    • Built-in Speakers: 3 W x 2
    • MultiView: PIP/PBP mode, 2x devices
    • User convenience: SmartImage, Multiview, User, Menu, Power On/Off
    • Control software: SmartControl Premium
    • OSD Languages: Brazil Portuguese, Czech, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Korean, Polish, Portuguese, Russian, Simplified Chinese, Spanish, Swedish, Traditional Chinese, Turkish, Ukranian
    • Other convenience: Kensington lock, VESA mount (100x100mm)
    • Plug & Play Compatibility: DDC/CI, Mac OS X, sRGB, Windows 8.1 / 8 / 7
    Stand
    • Height adjustment: 180mm
    • Pivot: 90 degree
    • Swivel: -170/+170 degree
    • Tilt: -5/20 degree
    Power
    • ECO mode: 31.5 W (typ.)
    • On mode: 55 W (typ.) (EnergyStar 6.0 test method)
    • Standby mode: < 0.5 W (typ.)
    • Off mode: < 0.3 W (typ.)
    • Power LED indicator: Operation - White, Standby mode- White (blinking)
    • Power supply: Built-in, 100-240VAC, 50-60Hz
    Dimensions
    • Product with stand(max height): 742 x 657 x 270mm
    • Product without stand (mm): 742 x 438 x 61mm
    • Packaging in mm (WxHxD): 970 x 526 x 224mm
    Weight
    • Product with stand (kg): 10.90kg
    • Product without stand (kg): 7.94kg
    • Product with packaging (kg): 15.20kg
    Operating conditions
    • Temperature range (operation): 0°C to 40°C
    • Temperature range (storage): -20°C to 60°C
    • Relative humidity: 20%-80%
    • Altitude: Operation: +12,000ft (3,658m), Non-operation: +40,000ft (12,192m)
    • MTBF (demonstrated): 70,000 hrs (excluded backlight)
    Sustainability
    • Environmental and energy: EnergyStar 6.0, EPEAT Gold*, TCO edge, RoHS
    • Recyclable packaging material: 100%
    • Post consumer recycled plastic: 65%
    • Specific Substances: PVC / BFR free housing, Mercury free, Lead free
    Compliance and standards
    • Regulatory Approvals: CE Mark, FCC Class B, BSMI, KCC, E-standby, ICES-003, KC, J-MOSS, cETLus, EPA, TUV/GS, TUV Ergo, TCO 6.0, PSB, CU-EAC, SEMKO, SASO, KUCAS, UKRAINIAN, PSE, CECP, WEEE
    Cabinet
    • Front bezel: Black
    • Rear cover: Black
    • Foot: Black
    • Finish: Texture
  2. Lived
    Lived n00b
    3
    Jul 21, 2008
  3. zoob
    zoob Limp Gawd
    181
    Jun 7, 2004
    Looks like a cheaper BL3201PH with HDMI2.0, minus control pod, and fewer inputs (1 less DP and 1 less HDMI). Not sure how compelling of a purchase this will be unless you really want HDMI2.0 instead of DP1.2.
  4. MistaSparkul
    MistaSparkul [H]ard|Gawd
    1,063
    Jul 5, 2012
    Well depending on the price it would be a very compelling purchase. The BenQ is nice but is too expensive so if this is $200 cheaper for practically the same monitor then that'd be nice.
  5. artbio
    artbio n00b
    17
    Feb 10, 2016
    I have ordered the BDM3275UP. However it has one bright pixel and a dark spot. There is also a vertical stripe of shadow in the middle of the display. Its is more visible on a white background. Does anyone with the same monitor notice this vertical stripe?
