Just started a master's in architecture, and we're doing everything in Rhino with maxwell as a renderer. So I just ordered this on newegg as a stopover until my next major system rebuild cause I didn't want to get a i7 + RAM + new mobo. Figure'd going from an [email protected] to [email protected] would cut out a nice amount of waiting with rendering times.
My mobo is the original rev 1.0 gigabyte ga-ma78gm-s2h, and I just noticed that after looking at the compatibility chart on gigabyte's site that the 945 is listed as compatible since BIOS F8, whereas the 955 is not?? I don't get how this could be as they're both 125w?
I just realized it may be because it won't run at stock speeds with the lower bus speed, and not having a high enough multiplier or something? I guess if it boots I could get it back up by oc'ing the bus/htt/etc so the lower multiplier can still get it to(over) 3.2ghz?
Anyone have a similar issue?
edit: emailed newegg trying to switch my order to a 940, seems thats what would work best with what I have and save a few bucks. Still, incase they don't, curious as to whether or not this would work.
