Phanteks TC14PE @ FrozenCPU.com for $49.99
Falkentyne
It's a NH-D14 competitor. But I don't remember any articles with temp comparisons.
The main issue with this cooler is the annoying mounting. There were some QC issues also.
doubletake
are these knockoffs off the Noctuas Nh-D15? Looks almost the same.
lolwat
Where you born the same year your made your account?
Phanteks has been around almost as long as Noctua has, putting out competing products of similar performance for a bit less $$.
There are only so many ways to make your competing chunk of copper, aluminum and plastic look different from everyone elses unless you start pressing custom fin designs, but that can end up looking tacky real quick.
dcun201
Ahh ok. Yeah if it performs the same as the Noctuas then this is a killer deal.
RPGWiZaRD
It's been around for many years already, been using one for many years as I could better match the case black & white color setup with the nice looking black and white color version. It's fairly similar in performance vs Noctua, the Noctua might be slightly bit more silent at the same fanspeed and has better memory compatibility and easier install than the Phanteks but they are quite similar in performance from reviews I've seen. One of the fans started developing some extra noise but Phanteks support sent me a new and slightly better fan for free even. Didn't fancy paying 30 or was it 35€ extra for the Noctua in the ugly brown color.
It's fairly low spacing for ram but you can obviously clip the fan a little bit higher up on the heatsink which helps if you have a bit taller ram provided you have the space in the case for it (I have the NZXT H440 New Edition White case so I'm good).
