DarkSideA8
- Apr 13, 2005
I may steal this.higher max brightness does not offset worse local dimming
I think it's just the size and hardware gsync, that makes sure the performance is buttery smooth in the whole fps range from 0 to the max and back. Max brightness is nice but not something to write home about and burn-in is rather mental issue. Given that VRR on the new C1 starts at 20fps, instead of 45fps like on the older models, the 48" OLED is even harder to beat than it was before. And definitely not with a $3000+ price tag... But if someone is rich and such purchase does not tank one's budget - no question about getting the PG32UQX.The only things it really has going for it vs OLED is the size, higher peak and sustained brightness in HDR and burn-in being a non-issue.
Yeah... for that we have to await actual reviews, not just previews.I think it's just the size and hardware gsync, that makes sure the performance is buttery smooth in the whole fps range from 0 to the max and back. Max brightness is nice but not something to write home about and burn-in is rather mental issue. Given that VRR on the new C1 starts at 20fps, instead of 45fps like on the older models, the 48" OLED is even harder to beat than it was before. And definitely not with a $3000+ price tag... But if someone is rich and such purchase does not tank one's budget - no question about getting the PG32UQX.
FALD reaction time is still a mystery btw.
I'm not surprised. It's also NOISY. (the gsync fan)Oof...that's quite a slow IPS panel.
So based on that review, it looks like it's pretty good, but is it $3000 great? The only things it really has going for it vs OLED is the size, higher peak and sustained brightness in HDR and burn-in being a non-issue.
Personally I'd rather get a non-mini-LED version of this for a much lower cost despite the hit you take in HDR quality. Or use that monitor on the desktop and get an LG OLED for HDR gaming and movies.
If they reveal the 42" next year around CES then it's most likely available around the following summer. At least that was the case for the CX.I saw the optimum tech review. I was disappointed with the fan noise. I wish we had a better idea when the 42" LG OLED TVs would be released because I think I would lean to that at this point even though 42" is still probably too big for me.
Also the fan noise is from the GSync - so as long as the 42 doesn't have one...If they reveal the 42" next year around CES then it's most likely available around the following summer. At least that was the case for the CX.
No, it would be 2x16 or 2x18. They would be columns of light that extend vertically from the opposing edges of the screen toward the center. Here is a video showing the type of backlighting in action on the Samsung CRG9. Do note that this monitor only has 10 zones, with each zone covering 4.7 inches versus the 1.7 inches that would be covered on a 16-zone 32" 16:9 monitor. The size of the zones on the CRG9 can give you an idea of what it would be like, though.Regarding the 'Q' version of this... When they describe edge lit dimming in 16 or 18 zones - is that a 2x8 or 2x9 grid?
(and - does anyone know of any panels with 16/18 edge lit zones where I can read about haloes, etc?)
(QX has the 1500 zones and GSync. Q is edge lit.) from TFT:
- The QX model has a very high end Mini LED backlight with 1,152 local dimming zones designed for optimal HDR performance (for an LCD display). On the other hand the Q model has only a normal edge-lit dimming backlight with a far more limited number of zones (expected 16 zones but not confirmed). The QX will offer much better local dimming and HDR performance with smaller halos, less blooming and the capability to offer superior brightness levels and dynamic range.
- As a result of the backlight the QX model conforms to the VESA DisplayHDR 1400 standard, including a peak brightness capability of 1400 cd/m2. The Q model meets the HDR600 standard with a peak brightness of 600 cd/m2 possible. Remember the limitations above though related to the number of dimming zones (1,152 vs 18).
The QX model is expected to retail for around $2999.99 USD if early pre-orders from Asus’ website are anything to go by. This is a very high end display with the price impacted significantly by the Mini LED backlight and Native G-sync module. The Q model should be a fair bit lower cost than this,
Also the non-1500 zones screens are likely coming in at a reasonable price point... In the Gigabyte thread it looks like next month and @ $1200.
Edit - the above statement is likely based on poor understanding... I thought the Gigabyte 32 was a contender - but it looks like it is only QHD.
That said - Viewsonic is releasing the 32 4k edge dimming version in Q3.
Yeah - I Googled the U and ended up on the Q page and got all kinds of confused... Then posted.? The Gigabyte FI32U is 4k, not 1440p. You must have searched up the FI32Q instead. Monitor makers and their naming...
If they were both using the (why do I always want to call GSync... NSYNC?) same GEE-SYNC module... why would the noise be much different?The fan noise from the Optimum Tech review is disappointing, especially for a what's supposed to be a high-end display.
What I wanna know is whether Acer will have their PG32UQX equivalent x32 monitor for release around the same time. I honestly prefer the aesthetics of the Acer model and if I recall correctly, the Acer x27 had a slightly less annoying fan noise profile than the Asus PG27UQ.
Different fan and/or heatsink.If they were both using the (why do I always want to call GSync... NSYNC?) same GEE-SYNC module... why would the noise be much different?
Its not going to be this year almost certainly. The 48" CX was announced in December 2019 and hit shelves in late spring/early summer 2020. I doubt they'd add the 42" to this year's lineup in the middle of the cycle, particularly because there's no "scrap" in their current fabs to source these from. They cut the 48" panels from the leftovers of the 77" panels and the 55/65 are cut from the same sheet. To make a 42" panel they'd have to make fewer 48" panels. Couple that with the fact that LG hasn't even said they were going to use this panel themselves (something that didn't happen with the 48") and it looks to me like they proposed the 42" size to see what 3rd party customers they could get to see if it was worth it economically to build a fab out that can generate 42" panels. That could mean we won't even see a 42" panel in the next cycle.I saw the optimum tech review. I was disappointed with the fan noise. I wish we had a better idea when the 42" LG OLED TVs would be released because I think I would lean to that at this point even though 42" is still probably too big for me.
Yeah. that makes sense. I would think that H1 next year is the soonest we would see it.Its not going to be this year almost certainly. The 48" CX was announced in December 2019 and hit shelves in late spring/early summer 2020. I doubt they'd add the 42" to this year's lineup in the middle of the cycle, particularly because there's no "scrap" in their current fabs to source these from. They cut the 48" panels from the leftovers of the 77" panels and the 55/65 are cut from the same sheet. To make a 42" panel they'd have to make fewer 48" panels. Couple that with the fact that LG hasn't even said they were going to use this panel themselves (something that didn't happen with the 48") and it looks to me like they proposed the 42" size to see what 3rd party customers they could get to see if it was worth it economically to build a fab out that can generate 42" panels. That could mean we won't even see a 42" panel in the next cycle.
Yeah I agree. I still plan to pick up a non FALD 32 incher for desktop use because like optimum, I also find FALD to be even more distracting to use in a desktop monitor vs a straight edge lit display. I honestly never notice the haloing that much in games on my X27 but on the desktop it was certainly more noticeable.
For sure. Whether it's a TV or monitor is a mystery. If a TV, it's going to be C1 electronics with a smaller panel. If a monitor it's most likely reusing whatever they had for their 43" LCDs or an iteration of that.Yeah. that makes sense. I would think that H1 next year is the soonest we would see it.
Even if you did, would it matter? lolI dunno, I feel no rush to upgrade to the next level gpu.
Which one you looking at? Acer XB323QK? At least it shouldn't have a gsync cooling fan...
I seriously doubt many console gamer are in the market for a pc monitor for their consoles. The average consumer only cares about price and size when it come to displays.The more I think about this monitor and the criticisms we are seeing from early reviews... the more I find myself curious as to Asus' choices here. I would think that in-house market analysis and testing could have served them better. If you think about everything we wanted and expected from this panel - it should have been shout-worthy, without caveats. The ONLY critique should have been price. Every other metric should have been out of the park.
- Out of the gate: a major critique (which does not affect me as a PC user) is the lack of HDMI 2.1 support. This is driven by the choice to use NVidia's GSync module, which in turn opens the panel up to 'fan noise' complaints. Given the strength of the console market and the open secret that the current iteration would be using AMD GPUs with HDMI outputs... This doesn't look very forward thinking - and it looks to me that by this choice, they're leaving money on the table (SeriesX/Sony 'enthusiast' spenders who will skip this because of form factor / connection choices).
- Fan noise: Acer and Asus previously put out 27s that competed directly against one another and used the GSync modules, but Acer's solution was quieter. Why open yourself up to unnecessary criticism of a high-price panel by not recognizing and fixing such a trivial thing? Do people really care about panel edge-thickness that much? (One justification that I've read for the smaller, louder fans relates to panel thickness)
- Blur: I don't know enough about the causes / solutions to this... but I'll bet Asus engineers do. If you're going to be the ground-breaker in large desktop, 4k fast IPS... make it look good. For the price, this should have been the crispest 4k Blurbuster ever tested. I'm hoping this is not a 'feature' of the AUO panel, because if so - I'm worried about the 'Q' model.
So - it looks like (to me) that they basically said, "Hey we have this great AUO panel that we want to turn into a ProArt monitor to compete with Apple and get industry people buy at a premium. It's got all these great features - how do we knock it down a bit in price to sell to gamers so we can get above the 'discount threshold' for number of panels purchased from AUO?" -- and the team just took off-the shelf tech from 2019.*
*Panel initially announced CES 2020 (Jan)
I agree with you completely - but every time I criticize console gaming... some wit comes out to say that they spend every bit as much on their hobby as I do on mine. (Smh/shrug)I seriously doubt many console gamer are in the market for a pc monitor for their consoles. The average consumer only cares about price and size when it come to displays.
I agree mostly but I think most people use cheap monitors also for PC gaming. Couple years ago I built my nieces a couple decent gaming computers. I come to find out that my brother just got a couple ancient throw away monitors from his work that used vga still ffs. He spent more in the dvi to VGA dongles then those monitors were worth. Both nieces were perfectly happy with the monitorsI agree with you completely - but every time I criticize console gaming... some wit comes out to say that they spend every bit as much on their hobby as I do on mine. (Smh/shrug)
To me:
Why anyone would choose to hook up a console in place of an actual computer for desktop gaming makes no sense to me at all.
- Console / controller = lounge on the couch / beanbag & game on a (relatively cheap) TV.
- Desktop / M&K = sit at a desk & game on a quality monitor
EDIT: I'm guessing the 'hook a monitor up to a console' crowd are playing in dorm rooms, BEQs and small apartments. My kid plays on an XBox and we've got ours set up in a finished basement with a TV on the wall.
Oh yeah. My son and I had to explain to my wife why he should be allowed to buy a 'gaming monitor' to replace the free monitor he got from his grandparents. (60hz cheap and ghastly looking TN panel from 10 years ago).I agree mostly but I think most people use cheap monitors also for PC gaming. Couple years ago I built my nieces a couple decent gaming computers. I come to find out that my brother just got a couple ancient throw away monitors from his work that used vga still ffs. He spent more in the dvi to VGA dongles then those monitors were worth. Both nieces were perfectly happy with the monitors![]()
Your setup is what I would consider a 'recent development' - and like you, I hear of people who have both Console and Computer hooked to the same monitor. Especially people who stream; makes life easier.I mean my choice in display is 100% influenced by whether it's suitable for both my RTX 3080 + PS5. I don't have a "TV" in the traditional sense where media is consumed, all of that is done at my battlestation.
For this reason my ideal display requires HDMI 2.1 as well as a convenient method for switching inputs (no 6 button/joystick menu presses).
I know tons of other people with similar set ups as mine and this idea that a console has to be tied to a couch/living room is really early 2000's.
I own both a powerful gaming PC, a PS4, PS5 and Nintendo Switch. I love playing on all the platforms but the consoles are hooked up to my LG C9 OLED TV in the living room. I really dislike this whole "console gamers are scrubs" stuff when most of the same games come out on both PC and consoles so you can choose whichever is more practical or cost effective for you. I love PC gaming for being able to tune the performance, mod games and play with any input method I like (I use Steam Controller for everything but 1st person games and strategies) but really appreciate how seamless and easy the experience is on PS5. I've had plenty of debates about this with a friend who plays way more than I do but does it exclusively on consoles and he just values the "fire up the console, get back to gaming" ease. Meanwhile on PC you need to launch some stupid store app, then load the game, then load a savegame before I can start playing. But it's still worth it to me like now I am playing Yakuza 6 at native 4K 60 fps which is not possible on consoles.I agree with you completely - but every time I criticize console gaming... some wit comes out to say that they spend every bit as much on their hobby as I do on mine. (Smh/shrug)
To me:
Sounds like you need a LG 48 CX/C1.I mean my choice in display is 100% influenced by whether it's suitable for both my RTX 3080 + PS5. I don't have a "TV" in the traditional sense where media is consumed, all of that is done at my battlestation.
