pfsense wan vlan question
Red Squirrel
I am trying to bypass my ISP provided router. Basically the internet comes in on vlan 35 and TV on 34 (I think, I have to double check). I got my internet to work by creating vlan 35 on the outside interface and assigning it as WAN.
What I want to do now is create a local Vlan and dedicate it for TV, I want to setup an outside interface on vlan 34 then simply "bridge" it to the local vlan that I create. Is there a way to do this?
I suppose another option is to add another managed switch before the firewall and just "split" the vlans at the switch but I prefer not to do that.
/usr/home
You should just need to add a sub interface on the WAN port that's tagged in VLAN 34. Not sure how to do that on PFSense though.
I'd create two subinterfaces on the WAN port. One for each VLAN and tag them appropriately. The TV VLAN should basically bridge into your internal VLAN for TV vs routing.
Looks like you may also need to set QoS preferences on the TV Vlan.
Red Squirrel
Ya I know how to do the first part, I'm just not sure how to bridge. Or do I need to make vlan 34 on the LAN interface too and it will do it automatically? I currently have vlan 35 setup on wan and that works nicely. My Pfsense firewall now gets an external IP, the Actiontec is not plugged in.
Metraon
Are you, by any chance with Bell ?
I found this tutorial not so long ago about bypassing the new Fibe modems.
Here
Red Squirrel
Yep Bell Aliant FibreOP.
Also I was accidentally passing local traffic on the IPTV network, I promptly unplugged everything before I break something. :p Also messed up my firewall and knocked myself out, had to restart it.
I changed my method. Plugging ONT directly into switch, set that port as trunk port allowing 35 and 34 only. I plugged firewall into port 2 which I tagged 35. Port 3 of switch is set to vlan 34 and is where TV will plug. Set Firewall back to normal WAN interface. Internet works, still working on TV. I unplugged the PVR and will plug it back in later. I think I still need to set some kind of port tagging, and not even sure if my switch supports that.
If I do go with this method and it does end up working, I'll want to pass this through everyone as I'm not sure if what I'm doing is even secure. Basically the switch that is plugging straight into my internet is also my internal switch, but I think with the way my vlans are setup I *should* be ok, but I'll specify more details and ask about it in a separate thread if this even does end up working.
Oh and that tutorial only covers internet. Internet is no issue, already have that working. I know there are some tutorials where you end up keeping the actiontec for the TV only, worse case scenario I may do that but I rather just eliminate it completely. I'll reset it to default settings so I can still plug it in for troubleshooting purposes if ever I have to call tech support.
Red Squirrel
Actually I think I am close. I just need to know how to set the 802.1p value on the TV port. I'm not too familiar with that spec/protocol so reading up. Hopefully my switch (Dell 3524) supports it.
Red Squirrel
I got it partially working!
To set the priority it was as simple as going into the interface and typing qos cos 4.
Now the issue is, the TV works, cuts out, works, cuts out etc... Really not sure why.
Metraon
Seem like you did the right thing but apparently they changed something recently to their network.
There is a discussion on dsl reports. I havent read all the thread, but prehaps they figured it out !
Here
I am curious too, because most of my clients are getting switched to FibreOP and some will get the IPTV bundle for their waiting room.
Red Squirrel
Already went through part of that thread (though I did skim it so going through again) but think they're basically doing the same thing I'm doing just a bit more complex due to their setup. I suppose technically I should have a dedicated ONT switch though, but the way my vlans are setup think I can get away with my current setup. It "works" just not fully, so there's something else to it.
I wonder if the MTU has to be set to something specific for TV. That would probably explain why I get part of the stream then it dies.
Though I'm also reading the actiontec does do a bit of special communication related to IPTV, it's not just a simple pass through.
Worse case scenario I may try to see if I can incorporate the actiontec but just for the TV. I think I read about that being done. The internet part is very simple as it's simply vlan 35 with nothing special. I think the TV has it's own separate NAT.
Red Squirrel
Well this sucks, even if I plug the actiontec into my switch it does the same thing. I get about 5 seconds of TV then it cuts out. I think I'm going to have to go back to the old way. :/ I hate having a double NAT.
Red Squirrel
Well ended up just putting everything back how it was.
At random my internet dropped this morning and I could not get a new IP. Even with the Actiontec plugged in I'm not getting an IP anymore. So I put it back how it's suppose to go and they actually want to send a tech. I don't know what he'll do but guess he'll confirm all is properly connected then get a higher level involved. TV works now though.
Really I was mostly trying to do this because I wanted to rule out double NAT being an issue for my Wii U to work but even without the double NAT it still wont work so it's not that.
Shockey
UPNP enabled on pfsense?
Red Squirrel
Tried to enable it for the wireless vlan (same as wii) and it still did not work. Though, I may have to try again once my internet is working since upnp on the Actiontec was disabled by default so it probably has to be enabled there too. What exactly does UPNP do anyway, I've never been able to find a clear answer on the internet, the description is way too general. Is it basically a protocol that allows LAN services to request a port forward dynamicly? Could it be a security risk to leave that enabled?
Red Squirrel
Ended up fixing my internet by rebooting the ONT. Totally forgot to try that, kinda glad I did before the tech came over. Would have felt like an idiot. :p
