DlStreamnet
- Mar 10, 2005
Execution of the command /sbin/fdisk -v -f /tmp/new.fdisk.ad0
Failed with a return code of 1.
Anybody had this issue? Trying to install by configuring PfSense then hitting 99 at the dashboard.
I'm using a MaxTerm terminal PC, with a 60GB IDE Hard drive using a laptop IDE > PC IDE adapter.
Installing PfSense using MemStick image. MemStick image works fine to boot and work from.
Tried using a small 3gb partition to install on to no avail.
Tried writing all to 0's to no avail.
Any ideas?
Any ideas?
