Any suggestions on my pfsense build? Will need this box to support 1Gbs between 2 LANs and would like to achieve as close to 100Mbps IPSEC. While keeping power consumption as low as possible
SUPERMICRO CSE-510-200B Black 1U Rackmount Server Case
SUPERMICRO MBD-X9SCM-F-O LGA 1155 Intel C204 Micro ATX Intel Xeon E3 Server Motherboard
Intel Core i3-2120T Sandy Bridge 2.6GHz LGA 1155 35W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32120T
Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) ECC Unbuffered Server Memory Model KVR1333D3E9SK2/8G - Yes I know overkill probably on RAM but it is fairly cheap!
Kingston SSDNow S50 Series SS050S2/32G 2.5" 32GB SATA II Internal Solid State Drive (SSD)
Intel EXPI9402PTBLK 10/ 100/ 1000Mbps PCI-Express Two Gigabit Copper Server Connections - OEM
Case Parts:
SUPERMICRO SNK-P0046P CPU Heatsink for Xeon Processor X3400 / L3400 Series
SUPERMICRO RSC-RR1U-E8 1U PCI-E x8 Slot to PCI-E Slot Riser Card
SUPERMICRO MCP-220-00044-0N 1x3.5" to 2x2.5" HD Converter Bracket For 5015A Series Barebone - OEM
Am I missing anything?
Here is a link to my newegg wishlist.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=26216088
Case Parts:
