pfSense box will not get WAN DHCP/Internet access from FIOS/Verizon
AMD_Gamer
I got my new pfSense box up and running great but i cannot get internet access. It does not appear to be getting the DHCP info from the isp.
I use FIOS internet (internet only) and tried to clone the mac address and still no luck.:confused:
Any ideas?
pwrusr
***Edit, no need to do this, see post 11 below***
Have you tried powering down the ONT for about 30-50 seconds? (may also have to pull the backup battery for about a minute as well)
pwrusr
Pull the power plug going to the ONT (Optical Network Terminal) and likely the battery backup as well.
Bad part is there are quite a few different ONTs that Verizon installed since FiOS launched...
This is what my ONT looks like (All in one ont + BBU):
http://img715.imageshack.us/img715/4075/img20101220124108.jpg
At the top is the battery for the battery backup.you should simply be able to reach in and pull one of the wires. Make sure you also pull the 110v plug from the wall for at least a minute.
Other examples:
http://www.broadbandsoho.com/Tellabs_611i_SFU_ONT-1.JPG
Battery Backup Unit (or BBU):
http://www-01.evenserver.com/s/mt/2010/q3/p1010990.jpg
AMD_Gamer
Still not working. I had everything powered down for over 10 minutes.
AMD_Gamer
Tried again this time resetting the pfsense box in case the dhcp service was not restarting. Still no luck.
cymon
How old is your FiOS service? You might be provisioned to use PPPoE.
pwrusr
I'd try to contact Verizon at this point... just be patient and calm ;)
Veeb0rg
Assuming you have an Actiontec Router.. Log on to Actiontec, click on My Network icon, then select Network Connections item. Click on Broadband Connection (Ethernet) in the table to see the properties for your WAN port. Write down the MAC address for the ethernet WAN port, you may need it later. Scroll down and click Settings. Click the Release button and your internet light on the Actiontec will go orange.
You should be able to put your pfsense router online and pull an IP now.
from dslreports http://www.dslreports.com/faq/15991
I had to do this when I swapped out the actiontec on my line. I did not need to unplug my ont.
AMD_Gamer
THIS WORKS! thanks a lot dude!:D
pwrusr
Thanks for the info and correcting me :cool: :eek:
