I'm pretty sure this has been asked (and answered) before but a "quick" search didn't turnip the answer I was looking for so....
I want to install pfsense on a PC. I made the pfsense CD from a downloaded pfsense ISO file.
Now, do I boot the PC with that Disc and will it then install on the hard drive in the PC ?
Can I instead install it and run it from a Flash Drive?
Reason I ask is because this PC has Windows10 installed on it and is one of my Primary every day work PC's and I do not want to harm the Windows install in any way.
so, to use that PC anyway, would I need to remove the hard drive that's in it and install one specifically for pfsense only?
Thanks
Thanks
