I would like the ek-hd 16mm petg tubing but it seems it only comes in 500mm (19.7") tubing each piece. I see some brands have 1000mm. Is 1000mm tubing needed or will 500mm work? I have a 900d case and all fittings will be confined to motherboard area and upper and lower radiators. Will NOT be using a bay res or anything in 5.25 bays.
Is there another good brand petg tubing that is good price, and not overpriced like the bitspower petg tubing. I don't care what brand as long as it works with either the EK-HDC or Bitspower Enhance multi-link fittings, both 16mm.
I know they say stay with the same brand of fitting as tubing, but does anyone know 2 different brands of tubing and fittings that work well together?
