9590 is slightly faster. But your wording implies you're asking if you should get the 8350?
Ill say the obvious just in case..
if you have a ssd and a hard drive the games have to be on the ssd to gain the speed.
So if you have an ssd now and expect better loading speed you won't really get it.
While I LOVE SSDs and could never go back to a regular spinning drive for my main OS and programs, SSDs do not have the performance boost you think they do once the game is loaded. IF you have enough ram to keep the game from thrashing due to caching, there is VERY LITTLE DIFFERENCE. Anandtech did a nice piece about it a while back.
Loading files doesn't invoke much CPU power at all, even if the files are compressed or encrypted. I haven't seen consumer level software with files so heavily compressed or encrypted that it made even the slightest difference. I also haven't seen a CPU so slow to affect loading times in more than a decade, even then it was dealing with the overhead of a particular RAID setup.
As everyone else said, if you want better load times upgrade your hard drive setup not your CPU.
Overclocking helps overall performance but you won't notice it as much as an ssd drive. Watercooling over air overlooking just allows you to push your processor harder, but it either way it stills depends on your ambient temperature. What games are you experiencing slow load times?
