Jun 26, 2004 #1 M Marc113- Weaksauce Joined Feb 26, 2004 Messages 104 Does anyone know of a good pentium III rdram motherboard that is socket 370. Or a slot 1 board that has been confirmed to work with a socket 370 to slot 1 converter. (all rdram)
Jun 26, 2004 #2 M Master [H] 2[H]4U Joined Mar 17, 2003 Messages 2,629 http://www.giga-byte.com/MotherBoard/Products/Products_GA-6CX7.htm# http://www.giga-byte.com/MotherBoard/Products/Products_GA-6CXB7.htm Those are what I can find. I'm not sure about the Slot 1 boards with a S370 converter, but I believe some do....I just don't know of any off hand.
Jun 26, 2004 #3 S SimGuy Limp Gawd Joined Oct 28, 2003 Messages 360 Asus CUC2. Socket 370. i820 chipset. UDMA/100. AGP4x. 2x PC800 RDRAM slots. 6 PCI. http://www.motherboards.org/files/manuals/1/cuc2-102.pdf
Jun 26, 2004 #4 G grethor Limp Gawd Joined Mar 1, 2004 Messages 188 intel vc820, i have one and it works fine
Jun 26, 2004 #5 M Marc113- Weaksauce Joined Feb 26, 2004 Messages 104 grethor said: intel vc820, i have one and it works fine Click to expand... This is the board i'm trying to upgrade. Unfortunately I have had no luck with the socket 370 to slot 1 converter and a coppermine 1 ghz pIII cpu. What is your setup?
