PDF Editor
Discussion in 'General Software' started by StarsFan4Life, Nov 5, 2009.
  1. StarsFan4Life
    StarsFan4Life Limp Gawd
    472
    May 29, 2008
    I need to edit a couple of PDF's (edit both text and create/edit fields) in the document. I do not want to pay an arm and a leg for Acrobat.
    What do you guys recommend?
  2. obobski
    obobski 2[H]4U
    2,387
    Aug 10, 2005
    Acrobat is the first suggestion, honestly
    InDesign is nice for editing PDFs as well, it also costs more than Acrobat (ok so thats a downside), but has A LOT more features
    StarOffice/OpenOffice can WRITE PDFs, but cannot EDIT previously created PDFs
    only thing I know of thats free is Foxit...
    could maybe try this:
    http://en.wikipedia.org/wiki/DocQ
  3. DeaconFrost
    DeaconFrost [H]ardForum Junkie
    10,924
    Sep 6, 2007
    Nuance makes some good PDF editing software for $100 or less.
  4. bigdogchris
    bigdogchris Wii was a Novelty
    17,638
    Feb 19, 2008
    http://www.pdfescape.com/pdf/account/ is a free online editing tool. Since PDF's are finished, you can write over them, not necessarily edit them. Maybe with Acrobat Professional or something high end paid for. Anyways, this site lets you use a 'white out' tool and you can insert new text as well as add fillable forms and check boxes to PDF's. You can also rearrange a PDF page order. I've searched up and down for something like what you are looking for and this is the only free editor I have found.
