PDA with GPS and VGA screen?
Potato
Hi,
I've been looking for a PDA with GPS navigation built in and with a 640x480 VGA screen. The ones I've found all have 320X240 screens. Are there any out there with VGA screens? What's the best one out? Asus Mypal 696 seems pretty good, although it only has the 320x240 screen. I'm hoping for decent battery life also.
Thanks!
Fujitsu-Siemens Pocket LOOX N560 seems to do the trick.
Theres a new HP coming out. Dont remember the number on it. Check engadget's last few days worth of mobile posts. HP 614 perhaps.
This one won't have a VGA screen though.
There's the 200 series with a VGA screen but it doesn't have gps - you'd have to use a cf/sd/bt unit.
Fine. Check the HP 910c. Its a business class device, but looks to be GPS equipped, not sure on VGA or not].
It's essentialy the same device as the 600 series, but with a differnt form factor. It doesn't have VGA.
Thanks for the suggestions. The LOOX N560 looks very nice, but from what I’ve read only has average to below average battery life and problems locking on to the GPS signal. I’m not sure how significant these issues are, because it looks like a very powerful PDA with all the features I want (other than high price :eek:). Also, it doesn’t seem to be available in the US, where I’m located. I’d have to import it from the UK or somewhere else.
