PDA Sync Problems
Codegen
I'm having problems syncing my HP H2210.
When I try to set up a standard partnership, it'll only stay connected for a couple of minutes. Then, it will automatically disconnect itself and I'll have to redock the PDA in order to get it to connect again. However, with a guest partnership, there are no problems.
I've tried:
Reformatting the machine
Different cable
Different versions of Activesync
Hard reset of the PDA
With no luck. Any ideas?
