PCIe or SATA III for new build?
Discussion in 'SSDs & Data Storage' started by Spaceye, Apr 19, 2017.
  1. Spaceye
    Spaceye n00bie
    19
    Apr 15, 2017
    Looking for suggestions for a dedicated ssd for windows 10.
    PCIe SSD?
    https://www.amazon.com/gp/product/B01JCXXQ0Q/?tag=tec06d-20
    OR SATA III?
    https://www.amazon.com/gp/product/B01LZ09A68/?tag=tec06d-20
    PARTS 4 NEW Build:
    Windows 10 Pro
    Monitor:
    Dell 43" 4k Multi-Client Monitor (P4317Q)
    CASE:
    NZXT Phantom 820 Computer Case
    https://www.amazon.com/gp/product/B009QZH23S/?tag=tec06d-20
    MOBO:
    ASUS ROG Crosshair VI Hero AMD Ryzen AM4
    https://www.amazon.com/gp/product/B06W2L6GBX/?tag=tec06d-20
    CPU:
    AMD Ryzen 7 1700 Processor
    (might go with 1800x for the extra 200mhz boost)
    https://www.amazon.com/gp/product/B06WP5YCX6/?tag=tec06d-20
    RAM:
    Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz
    https://www.amazon.com/gp/product/B0143UM4TC/?tag=tec06d-20
    GPU:
    2 GTX 960's (From old PC, planning on upgrading when a new series of nvidia gpu comes out)
    SSD:
    Plextor M8Pe 128GB HHHL PCIe NVMe Internal Solid-State Drive with Heatsink
    Storage:
    1T WD Caviar Drive, 3T Seagate backup plus & 4T seagate personal external HDs
    PSU: (Already bought)
    CPU COOLER:
    Still deciding on a water cooler...suggestions are welcome.
  2. FnordMan
    FnordMan [H]ard|Gawd
    1,733
    Apr 22, 2011
    None of the above? The linked motherboard has a m.2 slot, why use a bulky, expensive PCIe card when you can get a much smaller m.2 drive and still have it be PCIe? The 250Gig 960 Evo can be gotten for about the same price as the plextor you linked.
  3. mls1995
    mls1995 2[H]4U
    3,269
    Jan 20, 2007
    agree, use an m.2 slot.
  4. DMFD-Minister
    DMFD-Minister Limp Gawd
    402
    Jan 14, 2008
    As others have said M.2
    Same speed as PCIe
    Smaller form factor
    Probably costs less
    Small Edit:
    M.2 really only has advantage in MB/s. For day to day operations, you won't notice much of a difference. I have a very similar build and I'm going with 2xSamsung 850 EVO 500GB drives.
  5. Simplyfun
    Simplyfun [H]ard|Gawd
    1,176
    Dec 17, 2016
    The thing I really like about M.2 is that it just pops on the system board out of the way.
    The thing I really hate about M.2 is that it's stuck down there on the system board.
  6. Grimlaking
    Grimlaking [H]ard|Gawd
    2,021
    May 9, 2006
    Go with an M.2 NVME drive. It's worth it and your board has the slot. I love mine.
  7. Spaceye
    Spaceye n00bie
    19
    Apr 15, 2017
    guess cuz i just like the look of the plextor and I dont mind that its a little bulky.
    If price wasnt really a factor which one would you guys get as a dedicated steam drive (for gaming)?
    M.2 or PCIe and why other than the size?
  8. arestavo
    arestavo [H]ard|Gawd
    1,356
    Mar 25, 2013
    SATA III SSD - because for game load times and Windows boot times there isn't a difference between a good SATA III SSD and the fastest NVME drive in the world. We are hard up against other limiting factors including game queue depths (of 1 or 2, not deep queue depths) and file system formats (NTFS is ancient and slow).
    Scroll to the bottom of the first post for professional reviews that show the same results - https://hardforum.com/threads/nvme-...a-iii-ssd-game-load-time-comparisons.1911914/
  9. Gulvan
    Gulvan [H]Lite
    126
    Aug 7, 2016
    There was a video I saw a while ago that basically said that it isn't worth it right now for NVMEs as, at most, you save minimal time vs the money.
  10. Grimlaking
    2,021
    May 9, 2006
    For me it was worth while. I went from a 2600k i7 at stock speeds, with a Gigabyte 1070gtx video card, 16 gigs of ram, and a Samsung 840 pro 500gb drive. To what I have in my sig. Night and day... Yes load times inside of games are quicker but I did an across the board upgrade. If you are liable to have some buyers remourse later and plan on keeping it for 5+ years... NVMe is worth while. If you plan on replacing your disk subsystem, incrimentally over the years... then get a fast SSD and wait for more to take advantage of PCIE speed storage.
  11. 4330thgink
    4330thgink Gawd
    713
    Mar 8, 2001
    M.2 for operating system, swapfile, and whatever programs you can fit on it(depending on what size you get).
    Then for storage, use whatever floats your boat.
    I have my OS, swapfile, and main programs on my M.2. Then everything else is stored on RAID 10 spinners(thats what I had already), plus a couple single standalone drives.
  12. cybereality
    cybereality 2[H]4U
    2,743
    Mar 22, 2008
    Yeah, definitely get an M.2 drive. They are worlds faster, even than a high-end SATA SSD.
    I've been using the Samsung 960 Evo, which seems good. Also recently got a Corsair Force MP500 which I also recommend.
