PCIe adapter for SAMSUNG 950 PRO ,can you help me?
drugo
hi
i have an asus motherboard z-97K and i would like to use a SAMSUNG 950 PRO M.2 2280
i need PCIe adapter
i have a PCIe 3 for my x16 mode
and i have 1 x PCIe 2.0 x16 x4 mode for the SAMSUNG 950 PRO M.2 2280 & PCIe adapter
i would like to install windows 10 on SAMSUNG 950 PRO M.2 2280
what PCIe adapter could i buy?
thanks
drugo
I use a Asus Hyper M.2 X4 Mini and it works great. Only $20.
hi
do you whink work with my motherboard?
have you installed drivers?
and does the bios detect it?
my motherboard is not new
thanks
drugo
Yes
No drivers needed
Yes
hi
does it warm up? mostly SAMSUNG 950 PRO M.2 2280
just because i have an nvidia and the psu
the i have to mount Asus Hyper M.2 X4 Mini between the nvdia and the psu
thanks
PharetH
hi
thanks
I have not noticed any thermal throttling on my 950 Pro. It will really depend on your systems airflow. If you do get thermal throttling, there are little heatsinks you can buy and stick on the 950 Pro to help cool it down.
