I have a P5Q-E motherboard which has one pci slot width between where the cards would touch. I've read and listened to reviews stating 2 6970s in crossfire is incredibly loud. I recently upgraded to a 6970 and an eyefinity setup. I've also heard that having space between the 2 cards helps keep the volume of the fans down and reduces heat. Right now the 6970 doesn't usually bother me but sometimes in games it ramps up to 40% fan speed or around there which is definately audible and starting to get annoying. I'm wondering if crossfiring these cards would be unbearable soundwise to me? Would having a pci fan between the cards help or hurt the heat level? I'm looking at this page on newegg
http://www.newegg.com/Product/Produ...ption=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
if that link doesn't work then a card like this
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114024
This would move air between the cards but then the cards and this fan would be sandwiched together with no room between the 3. Would the space between the 2 cards either with a fan or without one make the cards not be louder than 45% fan speed on a single card? It would be nice to have 2 cards running for 5760x1080 resolution but I'm somewhat sensitive to having a loud computer.
