With the introduction of nvidia 20s series gpus they said that they don't officially support 4-way sli BUT am assuming that using (Bifurcation) we can bruteforce 4 gpus. 2 gpus in 2 x8 slots and 2 more gpus in 2 x8.
a few questions that i got are
1. If we take the 1 x16 and split it into 2 x8 and connect 2 2080ti, do we need to also connect an sli bridge between the 2 2080ti?
2. Has anyone done this setup to do a 4-way sli with the latest 20s series gpus?
3. which latest amd or intel motherboard can i use use to support it, i heard lots asrock motherboards has support for it.
For some that don't know what PCIE-BIFURCATION is, essensially splitting a x16 lane into(in this instance) 2 x8 lanes and connecting 2 devices into each lane. meaning that if you got 2 x16 slots in your motherboard you can split those slots into 4 x8 and connect 4 devices(in this example 4 gpus).
