I wonder if the final, release, drivers will tweak the fan profiles and power management to keep temps lower than that.
its a non issue. The 1080s and 1070s are around the same range arent the? in the low 80s?
Because there aren't any rules against it.
So long as I stay on topic and don't call people names, we can can have a discussion.
Reading your signature. I see you've pledged allegiance to AMD, so I'm baffled of why you have a 980Ti?
Please just sell it so we can stop hearing how much you hate it. Sell it now, make about $350 and you can buy two RX480s.
Something like that. It's just a bit unusual to see a $200 card hitting those temps. Though aftermarket coolers will handle that.
Thats cuz if you looked at the cooler you will see actually its doing a decent job lol. Plus we don't know we have seen most people saying the temps are in 70s so he could very well have higher ambient temps.
Idk I have heard quiet a few people in the past say that GCN usually get more performance per clock when overclocked vs nvidia cards.
He posted in another thread. Apparently he has the card he is not speaking much. But According to him voltage is currently locked. So this might be the reason I guess. AMD might be locking it on the reference cards, so looks like people are gonna have to unlock the bios on the reference cards. or may be its just the drivers but it might be locked on reference cards.
"ebduncan said: ↑
they could have put a 8 pin connector on, but I have no idea if It would actually help. Power consumption for me is under 115 watts. Biggest thing holding back overclocks right now is voltage control, which is currently locked. Board power being limited to 150 will hold back the higher overclocks most likely but no idea until I can do power consumption numbers with voltage control to see how much headroom there actually is.
Also while the specs are limited to 150watt, the 6 pin connector can provide more than its rated 75 watts. Kinda like my 290x which when overclocked can pull north of 400 watts abiet from 1-6pin and 1-8pin"
Hey he also stated thisAs I quoted "ebduncun" above, looks like voltage is locked on reference model. So no wonder we are getting all kinds of numbers. So bios mod looks like the way to go for reference it might just stay that way until AIB cards show up.
the rx480 will be on shelves on the 29th. Perhaps the 24th if AMD does decide to move up the NDA
There will be no non-reference cards at launch day. Most you will see is a bit altered clocks, and a backplate. Example at the 290/290x launch the XFX version of the 290 Black edition had a clock of 980mhz which was above the base clock of 947mhz. You can expect the same thing with the RX series cards.
I will also confirm clock speeds can be in excess of 1400mhz on the reference card when overclocked.
The new nvidia cards run in the 80s too though so not a biggie.
AMD Radeon RX 480 Supplies at Launch
I'm more inclined to believe.......videocardz.
Guess what I believed him when he posted that now not so much. I even posted referencing what he stated.
Its about the power draw vs. the temps vs the size of the GPU.
The Rx480 should be drawing less power, it should have less of a hot GPU, the reference cooler might not be as good as the FE coolers of Pascal.
The Rx480 should be drawing less power, it should have less of a hot GPU, the reference cooler might not be as good as the FE coolers of Pascal at least when cooling the gpu. They are quite a bit bigger than the ref. cooler of the the rx480 heat sink wise, fan looks bigger too.
Hmmm Curious if they will be voltage locked until proper review drivers?
Just throwing something out there. I mean i think its stupid to release overclocking utilities int he drivers that can adjust the voltage, but voltage lock the card? What the
Yes in excess of 1400mhz, with proper voltage.
the reference rx480 cooler sucks. I mean it works just fine, it's quiet and all, but it's not made for "extreme overclocking"
Yea he is saying that voltage is limited on reference cards. So probably bios lock on how much you can feed the reference card. probably to make AIBs happy and also allows them to use a cheap cooler and not have people burn up their cards lol.
Looks like a heatpipe based cooler and not a vapor chamber too.
So pretty much whom ever talking about overclocking over 1400, like the 1500 and 1600+ leaks were talking out of their ass? WTF tech and the forum poster that had a bother and friends in the business?
How do you know that if its voltage locked lol?
Yeah I was thinking the same thing about the cooler though.
1080 is vapor chamber I believe. I remember seeing pictures of it. I could be wrong.
He said its very limited on reference.
Let's hope it's not another 290x reference cooler type situation.
i wonder just how loud and high pitched these be at full speed? Blower so it cant be to good lol I remember my nvidia 280's were loud as fuck at full speed
say what? Now thats just wrong lol. No way in hell this is 290 sitution. 290 was no where near this price range and it was throttling and stock cooler couldnt keep up and they had to bump up the fan speed. From all we have heard is opposite with this card, it is cool and quiet and performs.
It's hard if you're a filthy casual.hard to tell from pics though
2 things worry me about the cooler.
1 - must be extremely cheap, since this is on a sub-$300 card. So cooling performance will be questionable, even with the low TDP.
2 - linked to 1. Since it's really cheap, it is likely that the acoustic profile of the fan is very undesirable, forcing AMD to low ball the default fan curve, leading to high average temps.
Number 2 is especially likely. We've seen that even with the premium vapor chamber cooler NVIDIA uses for their 1080, it still underperforms compared to the cooling load, especially at low fan speeds. Now AMD is using an inferior cooler, so it must have higher fan speed to compensate. If it doesn't, and AMD set the speed low, we may have a repeat of the 290x situation.
Just kidding.
Here's the 1070/1080 for comparison: http://i.imgur.com/8NhXMXd.png
