Overblod
- Mar 28, 2018
After a second or two after I click sleep, the PC would automatically wake up, this happens only when Ethernet is connected/enabled. If I disable it, and keep the wifi on, it does not happen, it sleeps peacefully. I have checked every wake on LAN setting on the Windows (10 Pro) and BIOS, nothing is turned on. Mobo is ASRock Taichi X99, has 2 LAN ports, behavior is common to both ports. Router is ASUS RT-AC68U, I have had 2 of them and the problem persisted on both. Even when connected through switch its the same problem. Anyone experienced similar problem? Is it a bad port/mobo?
