Long time reader, first time poster since I need a decent bit of help.
I normally leave my PC running 24/7, its been this way since the rebuild back in November. Other then driver issues with the video cards I have had no issues. Stable as a rock.
Out of the blue the other day I came home and found it had shut down, yet the surge protector was not tripped and then 22inch CRT was still on. When I went to power it on the fans spun up, but I got no post and the monitor stayed in standby, changed monitors no dice. I decided to take the entire thing apart and rebuild it, still nothing. Tried running it with only a single GPU, same thing, swapped out ram sticks, same thing.
Its worth nothing that the board is a foxconn nforce 590 and the debug LED shows 2x lines where the center of the number 8 would be, I couldnt find anything that says this means something.
The build: amd x2 4200+ 65watt socket AM2, foxconn nforce 590sli, 2x evga 8800gts, 1x Sony DVD RW IDE, 4gb corsair dominator ddr2 800, lian-li PC 1000-V, OCZ gamestream 600watt PSU.
Im trying to pin point just what died so I can replace it.
If (as I suspect) its the mobo Im debating moving to the ASUS Crosshair, is there anything I need to know about this, and will the heatpipe cooling go to hell in an inverted case.
Ive also learned about a potential ripple problem with the PSU so I might need to replace that. However getting it up and running is the first issue. I can remove a GPU and some RAM till I get a new PSU next month.
Thanks in advance.
Thanks in advance.
