I was wondering if anyone knows the performance difference between Patriot's LLK modules and their ELK modules (PDC22G6400ELK and PDC22G6400LLK to be specific).
I'd think that the LLK (low latency) ones would be better for overclocking and the ELK (eased latency) modules would bet better for value memory, but the box description on the LLK says "A perfect mix of Quality and Value" and the ELK box says "Gaming Memory for Extreme Overclockers.
Can anyone who has worked with these sticks help me out?
