I have Red Hat 9 with 2.4.20 kernel. I downloaded the cifs patch and extracted it into the /root. I also download the 2.4.20 kernel from kernel.org.
I extracted the kernel into /usr/src.
I run the patch -p1 < /root/linux/cifs_24.patch.
I then copy the /fs/cifs/* to the /usr/src/new kernel/fs/cifs.
I do "make menuconfig" and choose cifs support in the kernel. I exit and save.
Then "make dep".
Then I want it as a module so I do a "make modules".
The lastly a "make modules_install"
I download the mount.cifs into the /sbin.
I reboot. I do a mount -t cifs //123.123.123/share /root/share -o user=user,password=user.
It comes back saying "cifs is not a supported file system"
A couple of questions:
On a fresh install I have a folder 2.4.20-8 in my /usr/src folder.
Do I run the patch on that or the newly downloaded kernel from kernel.org?
How do I enable the module?
I know that the 2.6 kernel has the cifs support, if I upgrade the kernel to 2.6, will my settings and programs still work?
I have been going at this for 3 weeks trying to patch the 2.4 kernel with the cifs file system.
Then "make dep".
