Partition size for Win7 ultimate
Discussion in 'Operating Systems' started by gman76, Feb 4, 2010.
  1. gman76
    gman76 n00b
    62
    Mar 21, 2006
    I currently run WinXP from a C partition that is 15GB in size (D uses the rest of the 640GB drive). I'd like to do a clean install of Win7 Ultimate in the C partition. Can it be done, do you think there's enough room? Are there any options to choose NOT to install items (to save space) during the install? Will I risk corrupting the D drive which has all my data (personal data, music & videos)?
  2. DeaconFrost
    DeaconFrost [H]ardForum Junkie
    11,101
    Sep 6, 2007
    15 GB is below "safe" specs for even XP. I can't imagine wanting to confine myself to such a small OS partition. In your situation, the argument to install apps on a second partition absolutely falls apart because you are using the same physical disk. That argument is useless anyway, but I digress.
    Like I said, I couldn't imagine confining my system that much. if I had to use a single 640 GB drive, I'd make my system partition 100 GB, and leave the rest for data.
  3. NoForgiveness
    NoForgiveness Gawd
    770
    Feb 1, 2010
    Windows 7 system requirements:
    16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  4. gman76
    gman76 n00b
    62
    Mar 21, 2006
    OK, so can I install Win7 (no other apps) and get into the disk management tools to reallocate some of my free space on the D drive to make the C drive bigger?
  5. Sovereign
    Sovereign 2[H]4U
    3,080
    Mar 21, 2005
    No. You need to make the C: partition larger prior to installing Windows 7.
  6. gman76
    gman76 n00b
    62
    Mar 21, 2006
    Why 100GB? Seems like a lot of wasted space for me. The only other disk-consuming apps will be MS Office. So, 25GB should be more than enough - right? Or am I missing something?
  7. DeaconFrost
    11,101
    Sep 6, 2007
    I still follow the rule of allowing all kinds of free space for temp files and such. With hard drive space so cheap, why restrict yourself? Hell, if this isn't a laptop, why only run one drive? I am currently using a 320 GB drive, formatted as one solid partition for my C Drive, and a single 640 GB as my D drive.
    If you aren't installing any games, and the largest app you plan to install is Office, you could probably get away with something along the lines of a 30 GB, but even then I'd feel like I was cramped. On my work laptop, I have a 40 GB system volume, which doesn't get any larger apps than Office.
  8. gman76
    gman76 n00b
    62
    Mar 21, 2006
    Yes, I realize that would be best, but I want to avoid touching the data on the D drive. Seems that people are reporting Win7 takes up ~10GB of space after a fresh install, which will allow me to do the reallocation of the C drive. Maybe that "10GB" is for a x32 Home version. IDK.
  9. DeaconFrost
    11,101
    Sep 6, 2007
    If the data is that important to you, then you should back it up before hand just in case. If you don't have a way of backing it up, then you'll just have to take your chances (and it probably isn't that important to you). Anytime you resize a partition, you want to have the data backed up.
    If it was me, I'd clear the entire drive, and start with a blank, unformatted drive when installing Windows 7. Then, during the install, I'd create my system volume, and then handle the D partition once Windows was installed.
  10. Shockey
    Shockey [H]ard|Gawd
    1,994
    Nov 24, 2008
    I just recently did a install of windows 7. It claims it requires 12 to 13gb to install. Windows 7 also has a feature where if you override your old operating system it move all your files to a folder called windows.old in your C: drive. So you can install over the top of your old operating system and still have your old files to move to windows 7 ;) Without having to re-size your partition or jump through hops
    Just don't delete the partition!!!!!
    EDIT, During setting up windows 7 to install. Choose custom and it will show you the partition on your hard drives. Select the partition and it will tell you weather it big enough or not to install windows 7 on.
  11. ameoba
    ameoba [H]ardness Supreme
    6,413
    Jan 9, 2001
    Point of reference - C:\Windows on the Dell I just got at work (2 days ago) is over 12GB. That doesn't include any temp files used when installing.
    Maybe, while you're upgrading your OS, it'd be a good time to invest in an SSD to put the OS on ;)
  12. JaguarSKX
    JaguarSKX [H]ard|Gawd
    1,449
    Aug 19, 2008
    I installed a trial 30 day Windows 7 Home Premium on my PC last week. Right after installation, Win 7 took about 16GB or 17GB. I deleted all temp files and moved the Page file to a different physical hard drive. After that minor clean up Win 7's footprint was about 12GB.
    My C:\ drive is 40GB. I generally install all games onto a separate physical hard drive or partition. It makes backing up the C:\ drive easier and makes the backup file smaller.
