Parameter is incorrect (atypical)
Discussion in 'SSDs & Data Storage' started by Angelz3, Jan 21, 2019.
  1. Angelz3
    Angelz3 [H]Lite
    68
    Oct 30, 2011
    Hello guys,
    I've been having an issue with mounting a USB drive on my laptop, and I was hoping someone could help me more than google has.
    The two drives I have attempted to mount are:
    1) Samsung 64GB USB 3.0 Flash Drive Fit (MUF-64BB/AM)
    2) SanDisk Ultra Fit 128GB USB 3.0 Flash Drive - SDCZ43-128G-GAM46
    OS = Windows 7.
    Laptop USB = 3.0 and 2.0 ports (mounting unsuccessful in both)
    Every time I attempt to "Mount in the following empty NTFS folder" on either of the drives, I get the error from Virtual Disk Manager, "The parameter is incorrect." The error does NOT say that the drive in inaccessible or anything like that. It simply says "The parameter is incorrect," and nothing more.
    The goal I am attempting to achieve is to mount a USB drive and place my Dropbox folder in it, so that Dropbox doesn't have to sync to my laptop's main hard drive. I was able to successfully mount a USB drive in the past, but that drive died and ever since, I have been unable to mount any drive from any of the USB ports on my laptop.
    Steps I have attempted in order to solve the issue:
    1) Running chkdisk /f /r on the drive to repair any errors. Result: No errors found. Problem still persists.
    2) Reformatting the drive using the integrated Windows Disk Management interface (reformatting using NTFS for obvious reasons). Result: Reformat successful. Problem still persists.
    I have done extensive google searches and nearly every site/blog/etc says some variation of the same two steps I listed above and neither step works for me at all. I have not been able to mount any drive since the first time I mounted a drive on this laptop.
    Does anyone have any other suggestions to help me solve this issue?
    All help is greatly appreciated!
  2. drescherjm
    drescherjm [H]ardForum Junkie
    14,152
    Nov 19, 2008
    My guess is there are 2 partitions on the USB stick. One with some encryption software.
  3. Angelz3
    Angelz3 [H]Lite
    68
    Oct 30, 2011
    Thanks for the reply!
    Is there any way to check that there are two partitions?
    According to Disk Management, there is only one partition -- as shown in the picture below. Am I missing something?
  4. Angelz3
    Angelz3 [H]Lite
    68
    Oct 30, 2011
    Does anyone have any ideas about my current situation?
    I still haven't found a solution that works. :(
  5. mwroobel
    mwroobel [H]ardness Supreme
    4,867
    Jul 24, 2008
    Per Dropboxes page at https://www.dropbox.com/help/desktop-web/move-dropbox-folder
    • Removable media: SD cards, or any device considered "Removable media" by your operating system, are not supported locations for the Dropbox folder. Dropbox works best when hosted on your computer's main internal drive, or on a physically connected external hard drive. Dropbox can only provide direct support when the folder is hosted on your computer's main internal drive.
  6. Angelz3
    Angelz3 [H]Lite
    68
    Oct 30, 2011
    While I do appreciate your reply, the focus of my question is how to bypass those restrictions set by dropbox.
    In the past, I have successfully been able to virtually mount a USB flash drive and store my automatically updated dropbox files there. I simply let the USB flash drive remain in my computer at all times and everything ran smoothly until my laptop fell out of my car seat and landed on the USB flash drive, permanently destroying the drive.
    Ever since then, I have been unsuccessful in virtually mounting any USB flash drive. I have tried different USB brands, different USB capacities, and different USB ports on my computer, but all of them show the same message that I attached in my first post.
    Do you, or anyone else, have any ideas about how I could potentially solve my current inability to virtually mount USB flash drives?
  7. mwroobel
    4,867
    Jul 24, 2008
    Let me preface this by saying this is unsupported, and can (and maybe will) lead to corruption of your data. It is a crap shoot whether it will work, depending on how Dropbox traps the info and whether they simply rely on the removable bit or query the driver more directly. What you need to do is to flip the removable bit on the device. The easy way to do this is to use the Lexar utility which makes it a single-click affair, as opposed to the long way around by hand. You can find more info here.
  8. Angelz3
    Angelz3 [H]Lite
    68
    Oct 30, 2011
    Again, I really do appreciate your reply!
    I was able to virtually mount a previous (64 gb Sandisk) USB drive and use it for my dropbox files in the past. It worked perfectly, and there was no corruption of files. I understand that you would caution this method for storing dropbox files, but I personally have never had any issues with this method. My problem stems from the fact that the 64 gb Sandisk drive that I was using stopped working, because I accidentally dropped my laptop, and it landed on the USB drive which destroyed the drive.
    My current situation is that windows 7 is no longer allowing me to mount any USB drives. I have searched on google and found the link you mentioned prior to reading your comment. I have already attempted this method, and the Lexar utility does not work for either my 128 gb Sandisk or my 64 gb Samsung USB drives. It simply does not remove the "Read-Only (Only applies to files in this folder)" from the folders within the drive, even after re-formatting multiple times and trying the Lexar utility multiple times. I have tried mounting the drives multiple times after using I have also tried editing the drivers of the USB drives directly (the long way around by hand) but that causes my system to refuse to boot into windows until the changes are reverted.
    From my perspective, this issue has nothing to do with dropbox itself, and simply has to do with a flaw somewhere in my operating system or on my computer. I should be able to freely mount USB drives as I have been able to do in the past, regardless of the purpose behind my decision to mount them. Ever since my 64 gb Sandisk drive stopped functioning, I have not been able to mount any USB drives, and I am simply trying to figure out why this has happened.
    Thank you for your continued support and ideas! :)
  9. mwroobel
    4,867
    Jul 24, 2008
    When you say you cannot mount any USB drives, do you mean that if you plug one in it does not get a drive letter, or that you can't assign a USB device to dropbox? Just because you could do it with a particular drive and a particular version of dropbox in the past is no guarantee that you can continue to do it today. They are constantly updating their software and the methods they use to identify the mounted devices. Since they have explicitly stated that they don't support this (and are implicitly trapping against it) they most likely have a reason. That is most likely the reason you can no longer do it.
  10. Angelz3
    Angelz3 [H]Lite
    68
    Oct 30, 2011
    Let me clarify.
    When I connect a USB drive, it automatically gets assigned a drive letter like normal. I can also access the files on the drive (and add/delete files) as a typical USB drive should function. When I say I can't "mount" a USB drive, I am referring to my original post where I go into disk management and select "Mount the following NTFS folder..."
    As I stated before, this has basically nothing to do with dropbox itself. Dropbox is not necessarily the issue.
    The issue is that when I attempt to "Mount the following NTFS folder..." in the USB drive, I obtain the error "The parameter is incorrect" as referenced in the picture I linked my original post. I am simply trying to uncover the reason why I can no longer "Mount the following NTFS folder..." on any USB drives anymore.
    The process of "Mount(ing) the following NTFS folder..." DOES work on my other computers using the same USB drives, but it does NOT work on this particular laptop I have.
    Does this make sense?
    I do appreciate your support!
    (P.S. Below are some pictures detailing the process I am attempting to accomplish)
    HARD forum pics.PNG incorrect peram.PNG peram incorrect2.PNG peram incorrect3.PNG peram incorrect4.PNG
