So, for those of you that use this...
Can I only opt for either a hard disk backup or a file level backup?
I did a hard disk backup, but by appearances... I can't restore files from it. My only option is to restore the entire image, is that correct?
If that's correct, that means the only way I can restore files is just doing file level backups? Which means it won't grab the sector by sector info???
Edit- Mainly the SBS 2008 backup sucks for flexibility. I only want to backup twice per week and its only option is daily, which even includes weekends.
