P8P67 Pro 82579V NIC running at 100 mbit only?
Adam1203
Hi Everyone,
I have a P8P67 Pro with the latest 16.1 Intel LAN drivers installed (previously had 15.6 and 16.0). I have noticed on with each driver set, that my NIC eventually switches to 100 mbit and will not flip back to gigabit. I have ran the diagnostics and everything comes back fine. The only way to get it back to a full duplex gigabit connection is to uninstall/reinstall the drivers. Also, if I try to force it to a gigabit connection, the NIC just sits at "cable unplugged".
I have a Linksys E3000 with the latest firmware (not hacked). So I doubt it is an issue with the router.
Any thoughts, or others with similar issues?
Here's a screen:
bigddybn
An edgy cable could cause this pretty easily. Have you tried another?
The Mac
try a different port on your router. Ive had them go bad in the past.
