Although ALL external USB ports work great, the four internal motherboard USB ports will provide power for the front USB connections on the case and multi-card reader connection but cannot read data and there are four yellow bangs for them in Device Manger in Vista 32 bit.
I tried plugging in a spare multi-card reader, but same end result -- power but no data.
I deleted the drives with bangs in device manger so that Vista would reload the drivers, but the following error is shown in device manager -- any thoughts as what to do next -- everything else works great (Q9550 CPU, 4 GB Corsair memory and no OC'ing of anything with 1333 FSB).
Thoughts/opinions/solutions???
Thanks,
MikeSp (full error description follows from Device Manager):
This device cannot start. (Code 10)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
Description:
Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 10.
Problem signature:
Problem Event Name: PnPDeviceProblemCode
Architecture: x86
Hardware Id: STORAGE\Volume
Setup class GUID: {71a27cdd-812a-11d0-bec7-08002be2092f}
PnP problem code: 0000000A
Driver name: volsnap.sys
Driver version: 6.0.6001.18000
Driver date: 01-21-2008
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Thanks,
Description:
Problem signature:
Architecture: x86
Locale ID: 1033
