I just bought a Antec MX-1 hard disk enclosure to house a WD50000AAKS. When I rebooted my PC, I saw that the Marvel driver was installed during boot time.
I copied 21GB from my local drive to this external drive and it took 6 minutes. Not even close to the 3 GB/S as per SATA-2 standard. When I connected the HDD to a USB-2 port, the same data would take 14 minutes to copy.
The ESATA transfer rate does not even come close to the SATA standard of 3 GB/S. Is this a problem with the Marvel driver? If I use a ESATA bracket to connect the external HDD to one of the 6 internal SATA ports, would this improve the transfer rate?
