alright, do you guys have to be very careful when taking off the side panel or you might break off one of the plastic hooks? (particularly the bottom ones)
I have broken 2 of them and had to employ some adhesive to reattach. luckily, the adhesive is just as strong as the original plastic. (or unluckily, hehe).
I swapped the panels from left to right now so as not to stress the broken ones.
I heard antec is really good about sending replacement parts and I might replace some things soon...
