[Overwatch] Sinatraa Shares His Gaming Gear, NVIDIA Settings and Overwatch Settings
glhf6
Source: Gearrate
Mouse: Logitech G Pro Wireless
Sinatraa likes wireless mice because he doesn’t like the tugging feeling of wired mice. He also likes how light it is, and its 1ms response time as well as the Hero sensor.
When he plays Overwatch, he uses palm grip for Soldier:76, claw grip for Mccree/Widow, a mix of claw & palm grip for Doomfist, and fingertip grip for Tracer.
He doesn’t really care about the shape of the mice, whether it’s ambidextrous or ergonomic, as long as it’s comfortable for him.
He takes out the battery cover at the bottom of the G Pro Wireless to make the mouse as light as possible.
Keyboard: Corsair K63
His keyboard of choice is Corsair K63, because he likes its Cherry MX Red switch.
The reason he uses tenkeyless keyboards is because it’s easier for him to have more desk space in LAN tournaments and matches.
Mousepad #1: Corsair MM400
He uses a hardpad because he has “ADHD and I like to just move around”. Cloth pad feels muddy for him sometimes, and hard pad allows him to react fast and smooth at any given time.
Mousepad #2: Logitech G640
Sinatraa puts the Logitech G640 under the Corsair MM400. He doesn’t like to put his arm on the desk because it gets sticky, so he uses the G640 as a pad for his arm.
Currently, he doesn’t have to focus too much on aim. However when he does need to focus on aim, such as when he was playing Zarya, he played on Logitech G640.
Headset #1: David Clark H-USB
This is the headset he uses for Overwatch League matches. They’re created for high-noise environments, so players can’t hear anything during the match, unless the crowd is “really, really loud”.
Headset #2: Sennheiser GSP 600
Sinatraa uses Sennheiser GSP 600 at home because it’s similar to David Clark H-USB, but it doesn’t have as much noise cancelling.
It also has high quality microphone and headphones.
Monitor: HP Omen X 25f
Sinatraa uses this monitor for both at home and on Overwatch League stage.
It has 240Hz refresh rate, which is the highest refresh rate available as of now. He recommended everyone who’s currently using a 60Hz monitor to upgrade to at least 144Hz.
He also recommends using around 24.5″ as the monitor size, because it’s not too small and you can still see the whole monitor when you’re playing.
Chair: OPSeat Grandmaster
Sinatraa’s gaming chair is OPSeat Grandmaster.
NVIDIA Settings
Sinatraa recommends everyone to change the monitor refresh rate to 240Hz(or highest available) first.
He also always turns G-Sync off for every computer he uses.
The only thing he changes in 3D settings is Power management mode, which he changes to Prefer maximum performance. This allows your computer to always use full power, instead of trying to save power.
Logitech G Hub Settings
Sinatraa keeps the lighting options as the default.
He uses 800 DPI. And he keeps only one DPI option available in his mouse because he doesn’t want to accidentally change DPI in middle of a game.
His polling rate is 1000Hz.
Corsair ICUE Settings
Sinatraa recommends turning off the Visor lighting effect and use Static Color, because Visor effect bothers him.
Overwatch Settings
Video
You always want to use Full Screen to get the most frame rate.
He uses 200Hz even though 240Hz is available, because even very powerful computers can’t maintain 240Hz during a team fight. He wants to always feel a constant refresh rate.
He turns off Vsync and triple buffering. He turns on Reduce Buffering because he thinks it makes the input lag a little less.
He keeps Display Performance Stats On to watch his FPS.
For Limit FPS, he uses Custom at 300 Frame Rate Cap.
His graphic settings are 75% rendering, and everything else off or as low as possible.
Sound
He usually has his Windows volume at 100, so he uses around 70 for Overwatch Master Volume and Sounds Effects Volume.
He turns music off because it’s annoying during the game.
In-game Volume is around 85, Voice Chat Volume around 80, and Voice Chat Mic Volume around 70.
He recommends keeping off the Dolby Atmos For Headphones option, unless you’re really into surround sound.
Controls
Allied Health Bars needs to be On for all heroes, so you can know the HP of your teammates to decide if you should engage or disengage.
His sensitivity is 9.
His Doomfirst sensitivity is 7, Genji 16, Hanzo 4.25, Pharah 7, Soldier 7, Tracer 7, and Widow Scoped sensitivity is 34.33.
His crosshair is a purple Dot for most heroes, and a red Crosshairs for Doomfist.
Crosshair 1
Crosshair 2
All his keybindings are default, except Communication Menu. He unbinded it because he kept spamming Hello and gave away his position to the enemy team.
