Desdichado
- Apr 22, 2006
My backup system consists of a 1.8 Duron on an Asus A7N8x-E Deluxe with three sticks of 512 PC3200 in dual channel mode.
A few days ago, I started overclocking it. I set the divider to 133% and moved the fsb from 133 to 137. The multiplier on the duron is locked. I ran a full 32m of SuperPi and a full run of 3dmark05, and it seemed stable. Following the same proceedure, i made it up to 150 fsb and decided to stop there. So far no probs.
I left it there, and about two days later I was playing NFS:U2 and got a BSOD. I thought I was overheating (it was a warm day), i turned it back to 133 fsb. when i rebooted, i got a different bsod having to do with daemon tools. after i randomly got them for about a week, I ran memtest and pulled up errors in the 0-512mb range.
when i went through and tested my ram individually, the stick that was in the A2 slot turned out to be bad. I had run a full test with memtest about 2-3 days before i began overclocking, so i know the ram was good then.
my questions are, is it possible that i killed the ram by overclocking? I would not assume so, because it never went over 200 mhz.
Is it bad to overclock/run memory out of sync in dual channel with three sticks?
and why the heck was my first stick in A2?
I had another stick, so i'm still running in the same config. Was it just a random fluke that this happened or might the same thing happen again?
