Hey everyone, I'm new to overclocking and need some serious guidance!
I'm thinking of purchasing a q6600 with the new G0 stepping but I have some overclocking questions. First, I already purchased 2x1gb OCZ DDR2 PC2-6400 RAM and I'm not sure what numbers to try for overclocking. I've been reading that it is good to have a 1:1 ratio for RAM and cpu FSB. This would be fine for me if I could overclock to 3.6ghz (9x multiplier and 400mhz FSB) but I really doubt that I'll be that lucky. So instead I'm hoping to hit at least 3.2ghz but then I'd have to use an 8x multiplier with a 400 FSB to get a 1:1 with my RAM. But I hear it is better to use 9x multiplier at lower clock than lowering the multiplier with higher clocks. If this is the case, for around 3.2ghz, I would need 9x multiplier and a FSB of 355mhz. So in this case, would it be better for me to lower my RAM speed to match that of the cpu FSB to hit the 1:1 ratio? Or should I just leave it at 400 no matter what?
I guess my main question is, how important is it to have a 1:1 ratio between CPU FSB and RAM? Does it hurt to have the RAM faster than the cpu FSB?
Thanks everyone in advance.
