Overclocking a Dell (with Q8300 CPU), any way?
Shark974
So my brother has a Dell XPS 430. That comes with a Q8300 CPU, 2.5 ghz, 7.5X333.
We looked in the bios and there's no overclocking possible.
So is there anything we can do? There was a Windows program we looked into called SetFSB, but it didn't seem to support his exact motherboard from what I could figure. And even if it did, I think overclocking would be pretty handicapped without the ability to change the multiplier. It would take a 400 FSB just to hit 3 ghz.
So are we out of luck?
Tsumi
Yes, you are out of luck. Unless you manage to find a custom bios somewhere on the internet.
mda
Even if you did have a motherboard that could change CPU multipliers, you probably won't get far as the multipliers are only unlocked downwards.
