I seem to be having trouble overclocking my i7-2600K on an ASUS P8P67 Deluxe. I'm running the 1053 beta bios and I'm confused about the difference between the bios OC Turbo feature and the windows AI Suite II Auto-Tune program. In bios, the oc turbo gives me a turbo overclock of 43x103, but the autotune program only gives me 38x100. It says it will do stability testing but it never reboots my system to try anything higher. I'm a bit confused because 38x100 is stock turbo speeds. Also if my bios is set at 43x103, as soon as I boot cpu-z tells me I'm at max 3.8ghz on load. Does the AI suite override the bios settings? I have the same problem with fan xpert. In bios I have q-fan set on standard for both CPU and chassis fans, but once windows posts and AI suite opens, fan xpert defaults them both to disabled. If I manually change them to standard or silent, the changes don't seem to be saved on next reboot. Also I can't seem to change my turbo multiplier within the turbo EVO app. There's a button for turbo oc and it says to press ok and it will change something in my bios to enable multiplier changes within windows upon reboot. But after rebooting, it still says I need to enable turbo oc.
I'm hoping someone with a similar setup can give me a hand. It certainly seems more difficult than the newegg video on YouTube, where the asus rep just pushed a few buttons and got 48x100 in no time.
My other components are a new cooler master hyper 212+, OCZ modxtreme 700, 2x4gb mushkin silverline ddr3-1333.
