Output the sound of 12 iPads simultaneously
Metraon
I am searching for a mixer and/or something similar to output the sound of 12 iPads on speakers or monitors.
What would be the more cost effective solution ? (its for a non-profit)
The iPads have a custom made composition application for teaching kids the basics of music composition.
The iPads speakers are not that loud and we can't hear that much in the classroom.
Thanks !
(xpost from reddit)
Zepher
[H]ipster Replacement
24 channel mixer if you need both channels from each iPad or a 12 channel mixer if you just use 1 channel from each.
http://www.sweetwater.com/store/det...g&matchtype=&gclid=CLrBy5b_kL8CFTJp7AodBjgAvw
someone in the audio recording industry or music store may be able to help you out more with connectivity.
What I use on my iPad for audio is a Logitech UE Boom bluetooth speaker, but it is kinda pricey at $180-200, 12 of them is over $2k, which is very expensive.
http://smile.amazon.com/Ultimate-Ea...ie=UTF8&qid=1403562256&sr=8-1&keywords=ue+bom
They do have cheaper ones for about $30, Canz is one and it does sound ok and plays kind of loud.
http://smile.amazon.com/808-CANZ-Bl...1?ie=UTF8&qid=1403562230&sr=8-1&keywords=canz
basically you need a bluetooth mixer of some sort. i wonder if airplay solutions would work.
