StarsFan4Life
- May 29, 2008
I am sorta new to creating custom forms and templates in Outlook. However, I am trying to find a way to create a custom form/template in Outlook that can be saved for OM's to use on a frequent basis. I want to be able to create a custom fillable form where the only thing that can be edited is the fields where someone can enter in information. Below is the template and wording I would like to use:
P.A.R.T. SUPERVISORS DAILY REPORT
Call Out ________________
Tardy ________________
Driver Appearance ________________
Equipment Failure ________________
Maintenance Issue ________________
Route Issue ________________
Driver/s On ________________
Scheduled Time Off ________________
Customer Complaint_______________________________________________________________________________________
Driver Commendment___________________________________________________________________________________________________________________________________
SUMMARY_____________________________________________________________________________________________________________________________________________________________________________________
All the text needs to be locked down and unable to be changed by anyone...while the "______" fields are the fields that I need to be able to be tabbed through and changed. Is any of this possible? The reason I am doing this in Outlook is this template will be brought up in Outlook, filled out and emailed on to a supervisor. Any help would be greatly appreciated.
