Outlook 2002 - lost emails
Discussion in 'Operating Systems' started by Novice01, Jan 17, 2008.
  1. Novice01
    Novice01 n00b
    1
    Jun 8, 2007
    Hello
    I have lost my emails within a folder in MS-Outlook without any warning. The folder still exists but all emails within have disappeared. I don't beleive that I ever inadvertently deleted the contents no I have any filter applied.
    Any suggestions in recovering emails will be greatly appreciated.
    Thanks
  2. LoStMaTt
    LoStMaTt 2[H]4U
    3,185
    Feb 26, 2003
    Outlook 2002 is known to have "database" issues at times. Hopefully you have a backup PST file that you can restore but if not I believe you are out of luck.
  3. Blackforge
    Blackforge Gawd
    715
    Nov 16, 2004
    I assume you're talking about Outlook that is not using an Exchange Server and being delivered to a PST (Personal Folders) file? First of all, do not run a compress on the PST file and stop using the PST file. Make a copy of it otherwise new email will overwrite the space marked as deleted in the file (similar to a file system).
    These seem cheap, don't know what works:
    http://www.iolo.com/sr/4/
    http://www.recovermails.com
    http://www.recoverytoolbox.com/outlook.html
    You might download a demo of each and see if they have any reporting features on what they can recover.
    Never used any of those though. We use this at work:
    http://www.officerecovery.com/outlook/index.htm
    I swear by it, but its not cheap.
    Sorry, I don't know of any free utilities. There are plenty of expensive ones though.
    If you were connected to an Exchange server and the Deleted Item Dumpster was turned on, I could tell you how to recover instantly.
