I'm still running a 2600k @ 4.6. I started with an unlocked 6950. Moved to a 290x. Now I have a 1080, but the CPU is showing its age. I still game at 1080p @ 144Hz. Typically only CS:GO and Apex, but I get annoying fps drops and choppiness at times.
I'm pretty interested in a gen 3 Ryzen and I've been toying with the idea of getting a gen 2 now and upgrade later since, from what I've read, most MBs will be compatible with a BIOS update.
Basically, I'm looking for a quick CPU, MB, RAM upgrade without breaking the bank. The current Newegg deal with the 2700/X370/M.2 caught my eye, but I think I'd rather get a better/newer MB to be compatible with gen 3 later down the line. There seems to be a lot of value to be had right now, especially with gen 3 on the horizon.
So, my questions:
So, my questions:
- In my shoes, which MB series would you recommend? x470? B450? Any specific recommendations knowing that I want to move to gen 3 at some point?
- Then, I'm not sure I'd instantly want to move to gen 3 if I end up with a 2700 or 2700x. If there is a gen 3 refresh next year will they also still work with today's MBs? (Speculate)
- I've read these can be weird with RAM. Will I run into problems if I go 32gigs and what RAM would you recommend? Timings/Speed?
- Finally, should I just suck it up and wait for gen 3
